Quick poll:
What are your warm (170+ oil temp) oil pressure numbers?
Mine are in the 21-23psi range.
For VR30, spec is:Quick poll:
So I am a bit lower that spec then at 185 I am seeing oil pressure at 21-22psi.
That is bizarre that AWD specs so much higher oil pressure at idle but the same at 2k.
I don't remember form the dozens of oil weight debate threads...do you run heavier than spec oil also?So I am a bit lower that spec then at 185 I am seeing oil pressure at 21-22psi.
Something to keep an eye on.🤔
I saw that but haven't figured out why.That is bizarre that AWD specs so much higher oil pressure at idle but the same at 2k.
That should mean your oil pressure should be on the high side then. I run 5/30 also so Ill check mine next time I can get the scan tool on it and can find that parameter.Currently running Mobil-1 5w-30
