1 - 14 of 14 Posts
Do you all get a message on the bottom screen when you start up the car that says "Downloading all apps"? and if so, how long does it take before it goes away and you can use the screen?
You can set default apps that start and are useable immediately upon turning on the car...the others take about thirty seconds to fully load
isn't the bottom screen basically frozen for those 30 seconds while it's saying that? I found it annoying that I can't go to the radio screen as soon as I start the car.
Also, have you noticed that the lines on the backup camera don't work if you go into reverse right after turning on the car? ... Also, has anyone else had their whole touchscreen freeze? ... This happened to me a little while ago, I couldn't use the climate control hard buttons either. :(
YES. The whole damned system effing froze on me for two hours today. I am currently uploading a video. I am glad I'm not the only one.
Discussion Starter · #8 ·
The freezing only seems to be happening to hybrids.
My whole screen has frozen not allowing me to switch to different screens even with the hard button. Also very slow start up from start, more like 60-90 seconds before I can switch the radio, or see the reverse lines on the camera. Maybe an update will fix this? This is the Base Model btw
I've always heard that the future updates will be focusing mostly on speeding up the system.
1 - 14 of 14 Posts
