If it's RWD and you're in street tires, don't worry about 0-60 times. You're not going to do very well. The subframe cradle and pinion supports are far too soft for drag racing starts. The end links also deform. All of that deflection results in wheel hop and loss of traction. Something else that hurts it's stupidly short first gear ratio and the inability to start in second. It's hard to build any meaningful boost in first because there's just not enough load on the engine. Also, the inability to start in second is completely asinine and this is the first modem car I've seen that didn't let you defeat first for limited traction starts.
When the car launches, all the deflection loads up and absorbs force until it it can't anymore and then it rebounds quickly. It then becomes a cycle of compression and rebound until torque drops.
Sticky tires helps a little bit by sticky, I mean a full on drag radial, not an autocross 200tw tire or any of the UHPS tires. They can't do it. You need a DR from M/T or Hoosier for example. Wheel hop will still happen but the sticky tires will keep it from happening sooner.
The fix is to limit/remove all play in the rear cradle and tighten up the pinion supports. Then, being jointed links or very very high durometer poly. Then, maybe even set the static camber to +.5 or +1 so it goes back to zero camber on a launch and stays there during acceleration. Alternatively, swap in a solid rear axle. It'll hook like a boss then.
All of the will result in a luxury car....that isnt anymore. You have to decide what you want from your car.
