1 - 5 of 5 Posts
Hello have a 2018 q50 red sport. Just purchased my car about 2 months ago. Took it to infinity out here in palm desert. They said I had no coolent. My warranty couldn’t cover it. About 3 -4 weeks later. Fan is back on. Such as my heat gauge keeps going up and down. Not to far on the Heat but just little pass the middle. Should I take this car back ?
Check your coolant reservoir (the driver's side is engine coolant) level and report back, both cold and operating temp levels. For cold, you need to be at the "MIN" mark.
It could be your thermostat or your thermostat multi-way control valve. But this should be a warranty issue does your car have less than 70,000 miles? Get the dealer to fix this problem.
1 - 5 of 5 Posts
