1 - 15 of 15 Posts
2017 Q50 RS400
I just ordered a set of Volk Racing TE37 19x9.5 +22 for Front and 19x10.5 +22 for the back. Has anyone ran this fitment before? Also, will it clear my sport brakes?
I can’t answer your question but it sounds like a good question to ask Before ordering….
No idea what you plan on running for tires, so I made an assumption for the rear based on going with a much wider wheel.
100777
245 will be stretched on a 9 1/2" wide wheel.
I'm gonna put money on the rear ones rubbing on the fender.
Fronts:
100779
100780
I've decided that i'll just go with 19x9.5 square setup all around. As for the offset, would 22 offset clear the akebono brakes? My Q is a red sport so i have the akebono brakes.
I can't really answer that as the design of the back side of the spokes will dictate that just as much as the offset will. Try contacting Volk or a retailer and see if they have a fitment guide on their website or if they have any real-world experience.
2017 Q50 RS400
Discussion Starter · #10 ·
found a guy who is running the same setup i’ll be running. everything is gonna fit fine, appreciate the help
Good luck. And post up some pics when you get it done.
Had a 17 Q50s signature I ran 245/40/19x9.5 +22 without issues, moved to a 18 Q50s red sport I’ve tried to take those rims but didn’t fit unless I used a 22mm spacer (because of the brake calipers) from what I’m understanding I need a 9.5 rim with an offset around +45 and maybe spacers to make it happen WITHOUT a crazy poke.
2017 Q50 RS400
Discussion Starter · #13 ·
What wheels did you try to run run? i found a dude on IG who also has a red sport who’s running the same exact TE37 as i purchased down to the offset and width and he said they cleared the akebono brakes just fine.
I’m running 18x10 +20 Volk ZE40 on a 275/40/18 no issues
1 - 15 of 15 Posts
