1 - 10 of 10 Posts
Back when I bought my first G35 in 2004, I bought a set of Infiniti take off wheels and used them for my winter tires. I have used these wheels on my 2007, 2009 and 2012 G's.
Does anyone know if these wheels will fit on a 2014 Q50 Sport AWD?
What are the specs of the wheels u wanted to put on?
Sadly no, already tried... offset
Has any1 found a site that sells rims or tires or a package for winter?
Heh? Which one did u try?
19" Rims of Q50 have off set of 50mm, all other older rims were with offset of 30, 45 etc..spacers can solve the issue
Considering the stock G35 wheels are around a 30-33mm offset and the stock Q50 wheels are I believe a 50mm offset, I would say they probably won't work. Like gbert asked...what are the specs of the wheels you are thinking of putting on?
TireRack sells wheel/snow tire combos for reasonable prices. Mounted balanced and shipped.
Bolt patterns should be the same. Not sure on the offset. Have you tried bolting the old wheels on to see if they clear the brakes?
Just went through this with snow tires/winter rims for my Q50 Sport AWD. I will assume your old rims are 17". Your new Q50 has the big brakes and 17" rims will NOT clear the brakes! I found a nice set of 18" rims that provide the necessary clearance. The bolt pattern is the same as the 2009 G37xS I traded in and the 40mm offset works fine with 245/45-18 Hakka R2's (same overall diameter as stock wheel/tire combo). Check the Wheels, Tires etc. sub-forum for pics of my setup.
Discussion Starter · #10 ·
Thanks for the replies. The wheels are OEM Infiniti wheels from a 2004 G35. I have no idea what the offset is.
1 - 10 of 10 Posts
