I am curious if other people are planning on buying the hybrid version of the Q50, or the regular gasoline powered version. The regular Q50 uses a 320-hp 3.7-litre V6 gasoline engine, and starts at $37,500. The hybrid version uses Infiniti's Direct Response Hybrid System, which uses a 3.5-litre V6 engine, and starts at $47,000.
How long do you think it will take to make your investment back on the more fuel efficient hyrbid? Is it worth it for you?
I've posted on this before, but now I know better MPG numbers. The Hybrid is a little disappointing, since it will only average 31. The gasser will average 23.
Both Consuming 18 gallons of gas as a standard. Premium in my area is $3.72 a gallon, currently. So, either would cost about $67 ($66.96).
I put 13,323 per year on my current car for the last 8.5 years (have about 113,772 miles on it now).
The hybrid can go 558 miles on 18 gallons and the gasser can go 414 miles on 18 gallons.
In a year, for 13,323 miles, you'd fill up the hybrid (again, 18 gallons) almost 24 times (23.876). You'd fill the gasser (18 gallons) 32.2 times.
18 gallons, again, is about $67 (see above). 32.2 minus 24 is 6.2 times more for the gasser or $67 x 6.2 is $415.40 a year more for the gasser per year. The cost difference in similarly equipped hybrid and gasser is $1675 plus tax. In my area tax is 7.75%, so total cost difference is $1,805. $1805 divided by $415 is 4.35 years.
Your mileage, gas cost, taxes, etc will differ.
Someone said the hybrid has a larger gas tank at 20 gallons vs gasser 18. I used 18 so that would be the same.
I personally don't think its worth it for the loss of the fold down seats. I was hoping the hybrid had better MPG, but its made for performance more than fuel savings.
The gasser I used is a fully loaded sport AWD with all options vs a fully loaded hybrid sport AWD with all options, which are the two I'm considering.
I have to drive them both and look at the trunk but I'm leaning toward the gasser.
Wish I could get a Diesel engine in the Q50 for the cost of the fully loaded hybrid and I think it would get better MPGs. Performance would differ though.
