1 - 11 of 11 Posts
Alright so it's gnna snow here in NY tomorrow, and I usually put my wipers up so not that much snow sticks to it. I tried to do it with my Q50 but can't get the wipers up. The hood blocks/prevents you from doing so. Anyone know how?
reading OM may help:Instruments and controls 2-39;)
Pulling up the wiper arm:
The wiper arm should be in the up position
when replacing the wiper.
To pull up the wiper arm, push up*4 twice
when the ignition switch is in the OFF
position within 1 minute. The wiper operation
stops in mid-operation and the wiper
arm can be pulled up.
The shift lever should be in the P (Park)
position.
To return the wiper arm, place the wiper
arm in the down position and operate the
wiper switch once.
U have to pump that small shaft twice to get it to stand up! Hahahaha! :p
Just turn on the car or at least get the power to the car going then flick that stalk that u flick to control the wipers up twice! 1st on is to do the wipe and 2nd one to get it to stop! Once at the position u can simpy go out and pull the wiper blades towards u to get it to stand!
Hope that helps!
Reactions: maddsiick
Hope that helps!
You just made this whole process sound wrong.
If we can, might as well get a hot model to do it:D
I've given up! Tomorrow I'm going in for the DAS recall. I'll get the SA to show me.
You can get the wipers to stay in the "up" mode even while the car is on. Just do a quick double tap of the wiper level up (mist), and they will stay up until you change the wiper level position again. No need to make it complicated (KISS)
1 - 11 of 11 Posts
