Disabling Vehicle Stability Control on Q50
50K views 42 replies 15 participants last post by  BigHeadClan
As said above, unless you did some goofy workaround and put the Traction Control/VDC into a fault state in which case it defaults to totally off if I remember from the manual. In which case you just turn the car off and back on again and it will re-engage normally.
Reactions: StolenVr30
