CBE= Cat Back Exhaust. So.. thats from all the cats BACK.
You can get Full Downpipes (catted or "Race", w/o any cat, or Lower Downpipes, which retain the OEM primary cats but eliminate the SECONDARY cats. We have 4 OEM cats.
The secondary cats are the biggest restriction of the OEM exhaust system.
Full down pipes are a PITA to install in comparison to the LDP's. The performance gain between the full vs LDP is not "that" much and is why many do not get the full DP. (Or they want to do an easier install.)
Catted vs race DP .. big $ difference BUT is 48 state CARB legal (nothing is in CA now).
I opted for catted full DP's. Little to no difference between the two, but according to FI they got a couple of tics better with the catted downpipes. But I wanted cats and be legal. You also don't get the funny smell the non catted downpipes have.
Really should get LDP's at a minimum with the CBE. If you are going to tune and want as much umph as your tune will get you, get full downpipes.
I really don't see the point of spending the $ on a FI CBE w/o getting downpipes of some kind to go with it.
Forgot to add: Full downpipes are a bunch louder and you should get the resonated X-pipe with them unless you want LOUD.
