First sign of transmission issues
1 reading
13K views 12 replies 7 participants last post by  PrincessInMs
The 2014-2015 MY Q50's have had a semi-common issue with the Valve body I assume it would be related to that, but you'd need to have the Codes pulled and get a diagnostic done to confirm. There are various threads here discussing the issue if you search them up.
The code was a P0720 if I recall correctly, if that's what you end up with then snag a Valve Body off Ebay and have a transmission shop install it for you.
Reactions: Brianq50sport
