161 - 180 of 230 Posts
Good Day fellow members! Very helpful thread here and even after going through all 8 pages, I'm not sure is I am in the right place.
Here is the riddle, '19 Q50 Signature, Non Bose, No Nav. Over the weekend I installed a CarLinkLife Carplay module and also installed a 4-channel amp and ran the output back to the head unit, cut the wires at the harness and tied back into the speaker wire. Also connected my LOC to the front channel of the radio harness. The LOC also works as my remote for the amp.
This was a very slow process for me to do myself, haha. Like most of the weekend slow.
Anyway, when I put everything back together, and Carplay works with long press, along with its functions! However, now I am now stuck with both "Audio OFF" and "Climate OFF" always. I don't know about Drive Select Mode at this time. I ran self-diagnostic and only my AV Unit is yellow along with Radio Antenna, SXM Antenna, and the line between Audio Head Unit to DCU. Everything else is green. I took everything out again, and it looks like all my connections are good. Radio fuse was fine. I did not check the others.
Appreciate the feedback and help from anyone. I have not reset anything at this point. Hoping I can get this figured out.
-Need to recover my account!
Edit: Just found this -> https://www.infinitiq50.org/threads/q50-audio-off-radio-not-working-no-sound-audio-head-unit.143118/
I"m guessing you are going to tell me the same thing and I probably just found the answer to my own question.
What is your unit doing on the 2014 file?
Hello @nickdaria any update on the 2016 or any later years image file? I have a 2018 red sport with Bose/nav 360 cam. I just tried out the 2014 file but noticed I have now lost the Sport+ driving mode, haven't been able to test long enough to see if there are any other missing features. Thanks in advance!
Discussion starter · #163 ·
DM me. I have an image but I need confirmation that user data is removed before I share the link publicly.
Hello, I drive a 2018 Q50 and I'm wondering if anyone else has experienced this. I recenly installed an MK7 tesla screen from Aucar about 2 weeks ago. Everything was working perfectly for around a week and a half until couple of days ago when I noticed the audio and drive mode selector had sudenly stopped working. Afer some research I realized it was the DCU. After uninstalling the Tesla screen I could see that the DCU was powered on but just had a blank black screen.
1. Could the Tesla screen have caused this or is likely just coincidence? Seems like the DCU goes out fairly often so I'm hoping I was just unlucky and it wasn't caused by the screen upgrade becuuse I was really enjoying it while it was working.
2. Is the blank black screen fixable with a new sd card and flash or do I most likely need whole new DCU?
3. If it is fixable with a new sd card does anyone have a 2018 Q50 DCU image with AVM, Bose Audio, and Navigation?
Discussion starter · #165 ·
Those Tesla screens are hot garbage, but this is possibly a failure of the equally hot garbage DCU. I say remove the Tesla screen and verify the DCU is still having issues. If it is, do the SD card replacement with the 2016 image and test again. If good, reinstall Tesla screen
Slightly related but a little different, you seem to be quite knowledgeable, but do you think if I installed the MK7 from Squarewheelsauto but on a separate note had the transmission drain and filled done by Infiniti about 2.5 weeks ago that disconnecting the DCU (I sadly didn’t disconnect the battery so dumb move on my end) could result in TCM issues and the eventual P0720 on my 2015 Q50 or is it more likely due to the the transmission being serviced? I got the car about 8 months ago now, at 24K miles and now it’s at 28K, so it does have Infiniti’s actual warranty until almost 90K miles. But I guess the timing of both changes and this issue popping up this week has me confused. Regardless I’m Going to reinstall the normal lower screen, I should probably just disconnect the battery before doing that and see what happens. I just haven’t really heard anyone get this code from a Tesla screen installation. Also it has all packages, tech, deluxe, nav, and the Tesla screen has handled every feature quite well, so I guess if it was electrical I’d almost expect hiccups if somehow the Tesla screen installation could disrupt the TCM
LOL, I agree i have put 3 in and they all have minor quirks and i felt the volume had issues.
owns 2017 Infiniti Q60 AWD Red Sport
Discussion starter · #170 · (Edited)
Thanks to help from @fuzeshadow we now have a verified and clean 2016-2019 image. Please see the original post for details.
Havent tried yet, thought it will lack hybrid power flow etc.
All the hybrid features are there, power flow, battery charging etc. Make sure to use a high quality micro sd card like max/high/industrial endurance from SanDisk. The lifespan on these are years over regular cards.
@nickdaria
Hey man. Thanks for all your help on this thread. 2015 q50s. So i did the reset in the diagnostics menu...lol. been to 2 dealerships and neither knew how or couldn't reprogram it, then charged me a bunch of money. I've tried a used one out of a 2016 model and everything works except audio, it says there is a configuration table error and speaker shorts. Green line to the amp but red dot there. Wiring is good and getting power to everything, even the speakers. Tried a different amp, same thing.
Is my replacement dcu just no good either? Maybe I need a 2015 model dcu for compatibility? Seems like I should be able to replace it with one that will work, but maybe I'm wrong. I just don't know where to go from here. Tired of giving money to dealers, but I'll buy more dcu's if that will work, lol. Thanks
Hey, I have the same problem. Were you able to get everything fixed just by replacing the DCU? Also been to 2 dealerships, and they had no clue what to do.
Discussion starter · #178 ·
The dealer is able to do factory configuration from CONSULT. "Manual configuration" is the function name in their software.
