Has anyone done a manual swap into an Q50? if so can you give some insight im debating on getting the q50 but want a manual transmission.
I want to do this to my 2014 Q50S with 72k miles.I’m swapping my Q. If you have a 3.7 it’s very straightforward and very minimal wiring needs to be done. The 3.0T is another level of complication. I’m just using a 370Z transmission, 370Z clutch and flywheel, 370Z brake and clutch pedal and custom length braided clutch lines. I ended up ordering the 6MT Q50 diesel center console as well to make it a factory fit. Feel free to PM me if you need information.
How about posting a dedicated thread with pictures and info as you progress thru the swap?
13B rotary swap it. You’ll get way better flames, unique idle, and higher redline.Bro got my car admin tuned N/A and was pushing flame map in 2nd gear going 60 and now the car won’t go past 2nd gear in ‘D’ or won’t switch to semi-manual whatsoever. You think I blew up my transmission or valve body? Should I go for 6 speed 370z manual swap?
