Just guessing but I would guess that Infiniti is opting for a lower boost that will improve wear rates. The high boost turbos have lots of blow-by around the piston rings, which makes changing oil much more regularly a necessity. And then there is the valve stem sealing issue with positive intake manifold pressures. And the valve cover needs to be able to withstand hundreds of pounds of force that will try launch it through the hood of your car (unless it is vented).
If an engine is only designed to last 10,000 miles, then boost as much as possible. But if you want an engine to last 200,000, you have to reduce the boost. Which is why Infiniti will be introducing a 3.0 L Turbo. It is likely the sweet spot between boost/power and wear - at least for now.
I personally think turbo is the way to go from a power density point of view. But there are lots of little issues associated with a positive intake manifold pressure. The higher the boost, the bigger these challenges become.
I don't think the Infiniti community would like the idea of changing oil every 2500-3000 miles. I think the Benz community would be much more amenable to the higher oil change rate IMHO.
