System malfunction message and cannot shift out of Park
1 reading
8.1K views 6 replies 4 participants last post by  Avedis53
#1 ·
So thanks to the help that I received from this very same forum, I now have a working right tail light and tag light.
However, when I turn the car on I cannot shift it from Park to Drive and I get the System Malfunction error along with several other error messages. Could I have accidentally unplugged or messed up something in the IPDM oh when I had to access it yesterday to replace the fuse?
2016 Infiniti 2.0t
#2 ·
You did not state you had a 2.0t version of the car in your previous post. You're lucky the IPDM E/R layout is similar and fuse #60 is in the same location as the VR30 variant.
It could be that your stop lamp switch in the brake pedal assembly isn't sending a signal to allow you to shift. I don't suppose you have access to an OBDII code reader. That would sure help if you could list any DTCs that come up.
#3 ·
Is that a separate switch from the one that illuminated the stop lamps? I think I remember this topic from the past...two separate switches. It's not as simple as just looking to see if the brake lights work.
#5 ·
Some OBDII codes would be nice as well as pictures of all the errors being displayed.
Reactions: rpiotro and Pillboy
#7 ·
The stop lamp switch is off until the brake pedal is pressed. It sends a signal to the ABS actuator and electric control unit. The brake pedal position switch is on until the brake pedal is pressed. It sends a signal to the ECM. The ECM compares the two to see if they are in agreement.
