Vr30 transmission VQ
157 views 7 replies 5 participants last post by  Avedis53
#1 ·
Good morning everyone. I’m looking for some help I have a 15 q50 with a VQ I’m having transmission issues. I recently came across a steal of a deal for a VR transmission and I need help. My Q is awd however the vr transmission is rear wheel. Is it possible to simply swap the transfer cases on the transmission to convert the rwd trans to awd?
#2 ·
Transfer-case is part of the transmission for the AWD system to function, you need to start there the bell-housing and other modifications are also required.
#5 ·
I have AWD REDSPORT, you can remove the AWD SENSOR under the hood. It’ll run like AWD with no error other than AWD error on dash. Thing is it’s never just a easy simple swap with the Infiniti. It may be a connection somewhere requiring transfer case and transmission meant to be connected in synchronization.
#6 ·
What AWD sensor is under the hood? That's news to me.
Simply pull fuse #70 (10A) in the fuse box by the window washer fill pipe to disable AWD.
