Hi, I'm a new owner of a 2013 Q50 hybrid and running into a problem I can't find any info online about. The car is equipped with remote entry and keyless start BUT it will only start when the key is placed in the little compartment in the center console under the two screens near the shifter. If the key is anywhere else in the car, all I get is "key ID incorrect" on the screen. Touching the start button with the key also works.
The problem is consistent and replicable, identical with both keys and I replaced both batteries - still the same. Coming from a car where I could keep the key in my pocket, this is super inconvenient and I'm hunting for a solution. FWIW opening and closing the car works as intended and touching the handle unlocks correctly.
Is this a known issue? I got the car used so it's possible that the previous owner added/changed something to make it this way. I dug through the settings and found nothing, is there maybe a hidden/service settings menu of sorts where this is set? Possibly a security feature that narrows down the "keyless start" range to just that area?
