P0101 from BOV?
Tags
bov hks leak p0101
1 reading
14K views 39 replies 12 participants last post by  Oscar23
#1 ·
I installed some BOV HKS knockoffs.
After install I am getting P0101 codes on Both banks. I triple checked my connections and do not see anything not snugged down or anything.
Can these BOV’s be the issue themselves?
Link to BOV below.
I also have LDP, JB4, axle back.
#2 ·
If you're seeing P0101, that doesn't apply to both banks. P0101 means the passenger side MAF sensor is sending an abnormal signal to the ECM. P010B would indicate the same problem on the driver's side.
I'd suspect your BOV installation is mucking up your MAF readings somehow, most likely due to an air leak somewhere in the installation.
#4 ·
I only started getting both codes after I got JB4, I was running just AMS intakes for a while, and never got any code. Still not sure what it is.
#13 ·
Poor drivability is why I sold my kit. Below explains the details.
Reactions: Feeldabo0st
#12 ·
So, I took it all back apart replaced the pvc hoses and replaced everything with metal clamps.
Still the same issue with both sides of MAF. I unplugged JB4 and it does the same.
On the driver side it does sound like there may be some vacuum leaking but it has sounded like that since my initial install. I didn’t think to listen prior.
The leak seems to be coming from the left of the MAF below the manifold. Nothing there I removed, and I can feel anything or see anything.
I am debating on whether or not to remove the BOV altogether just to have this thing driveable, which in turn should tell me if I have a leak still theoretically.
#15 ·
I figured it was the BOVs as I mentioned in post #2.
Reactions: mmitsakh
#20 ·
^This is the real issue. Counterfeit HKS BOVs have been marketed by ebay resellers, so I'm not surprised you are having issues.
If you want to invest in BOVs, this week would be the time to buy non-counterfeit/legitimate BOVs from known Q vendors, such as Concept Z Performance:
96672
I have not seen a better price on Q50/Q60 VR30 BOVs since they started to get offered in the marketplace.
Both HKS and Turbosmart do the job, with HKS reportedly giving you the more obnoxious "blow-off" sound vs Turbosmart, which is much more subtle.
#23 ·
Do these BOV's eliminate the issue with the MAF not getting the correct readings? There is a video on this thread and the guy is explaining that BOV's on a MAF car will always throw codes? I'm new to such a new turbo'd car so I'm still trying to understand some of this stuff
#27 ·
They can offer a benefit if your car likes them. Mine did not. If you have an Ecutek tune it helps with throttle slam shut compressor surge by cracking open the throttle blades when you are in boost and suddenly get off the throttle. Bottom line is non recirculating BOV units are just not ideal.
#34 ·
P0101 is indicating an out-of-spec low or high frequency signal from the MAF sensor to the ECM on the passenger side. P010B would be for the driver's side MAF. I would have tried using MAF cleaner first before replacing them. Wiping isn't enough. I don't know if it is necessary to replace both MAFs if you're not getting a DTC for the driver's side MAF but if it has oil on it as you indicated, then I'd try properly cleaning both MAFs first before replacing either.
