Q50 hybrid fog lights not working and dash light dissapeared
621 views 11 replies 5 participants last post by  CWill14Q50S Hybrid
#1 ·
Basically everything was said in the title my fog lights no longer turn on and I also don’t have the light on the dash that’s on when you turn your lights all the way to fog lamps on with headlights… I’m thinking it’s hopefully just a fuse or relay but I don’t know where to start I wired in the led front emblem not too long ago and also the skyline trunk emblem in the rear. They worked fine for a while after first the front emblem then maybe a few weeks after the rear emblem they stopped working. Any insights where the fuse or relay may be for them is or if it’s most likely an electrical short would be helpful thanks
#2 ·
You should check fuse #57 (15A) in the IPDM next to the battery first. That fuse protects the fog lights.
#4 ·
Use an extended diag scan tool to force turn on the lights. Although it could be the aftermarket stuff, the indicator would still light up with a blown fuse. Maybe it's the actual signal from the stalk.
#10 ·
I am having a lot of electrical problems I actually think there might be something wrong with my abs occasionally my cars breaking will become terrible the brake pedal will sink and it won’t stop very well then come to a jerking halt all of a sudden it’s happened a few times the only way to fix it was to turn the car on and off multiple times until it would drive normally again… I also got this thing called roar pedal that I can set the accelerator pedal sensitivity I wonder if it is causing problems too.
