Have literally never seen anything anywhere about one.... i see parts but no videos of one actually modded. Do they exist? I've seen some some 400 hp CLA 250s with bolt-ons/tune i assume since its the same engine someone would have done something.
I think thats a different sensor. For me i need the manifold sensor/ camshaft (sensor)/ boost pressure sensor. I think imma take it to a machanic since i cant find the screws to take off the air intake systemI thought the pressure sensor is #6 in the first diagram and #4 in the second.
On the second diagram you think you can post or show the labels for each number to know where they belong? in the pictureI thought the pressure sensor is #6 in the first diagram and #4 in the second.
What car is that picture from? Doesn't look like an Infiniti 2.0t engine layout to me. It's a MB 2.0t engine though.On the second diagram you think you can post or show the labels for each number to know where they belong? in the picture
Wooow this is going to help me soo. Im surprised how helpful the q50 community is unlike the q60 community. Im still surprised you managed to get good diagrams. Also is there a special tool i need to buy to remove those mounting rubber? And also if their a one time use or can re install them again?What car is that picture from? Doesn't look like an Infiniti 2.0t engine layout to me. It's a MB 2.0t engine though.
These diagrams are for a 2016 2.0L Turbo. After staring at the diagrams some more, I think the manifold pressure sensor you're looking for is the pressure sensor downstream of the throttle valve (#16) for the "B" connection, not the pressure sensor downstream of the air filter that I referenced above.
#12 in this diagram is the pressure sensor upstream of the throttle valve which is what it appears to be the boost pressure sensor for the "A" connection.
The exhaust camshaft position sensor is where your picture shows it (#6) for the "C" connection:
As far as removal of the air cleaner housing, after removing the inlet and outlet air ducts, it appears that there are studs on the bottom of the housing that press-fit into 3 rubber mounting grommets. See below:
We aim to please. The diagrams are from the 2016 Q50 Service Manual. The housing appears to me to require removing the two air ducts and then pulling the housing upwards with some wiggling action. Simply center the studs that are on the bottom of the housing back on the rubber grommet holes and push down to reseat the housing.Wooow this is going to help me soo. Im surprised how helpful the q50 community is unlike the q60 community. Im still surprised you managed to get good diagrams. Also is there a special tool i need to buy to remove those mounting rubber? And also if their a one time use or can re install them again?
Any type of tools to use to take off the air filter box out?We aim to please. The diagrams are from the 2016 Q50 Service Manual. The housing appears to me to require removing the two air ducts and then pulling the housing upwards with some wiggling action. Simply center the studs that are on the bottom of the housing back on the rubber grommet holes and push down to reseat the housing.
Thanks for the link, I gave this guy the like (I usually do not give likes on YouTube). (Funnily, by the end of the video, there was a siren wailing, and bro looked momentarily aside with a concern.This may help those guys that are looking to tune their 2.0T Q's
Good luck.
Q50 2.0T Tuning Options Video
Thank you! Based on your info I managed to install a tuning box for my Infiniti Q60 2.0T.What car is that picture from? Doesn't look like an Infiniti 2.0t engine layout to me. It's a MB 2.0t engine though.
You can find them on Ebay or just by typing it in google I found one on Ebay for about 400Looking for help finding a good intercooler upgrade kit for my Q50 2.0T any recommendations.
What hp does a 2.0t with jb4 make?
Yup here u go 2.0t Stage2 Burbke TuneHave literally never seen anything anywhere about one.... i see parts but no videos of one actually modded. Do they exist? I've seen some some 400 hp CLA 250s with bolt-ons/tune i assume since its the same engine someone would have done something.
yep def not a lot of 2.0t but why not. Im not into drag racing or anything. Tuning it will just make it a funner experience for me while driving.
i have a 2018 2.0t luxe and I’m trying to put an oil catch can on it but I haven’t seen any videos of anyone installing them.. anyone has any videos of someone installing one for a 2.0t?Thanks homie! Feels good to know im not the only one modding a 2.0T !
