I just got this car, I have not put more than 1,500 miles on it. It's about to clock 40k any day now. I have never owned a Q50 or an Infiniti so I am learning a lot as I go here. I did not know these 3.0t turbos were such crap! And yes I think they are if everyone is having failures between 20 and 50K miles. That is BS when its a $5k fix every 2 or 3 years! When I first got the car the Turbos where amazing! Of coarse it was 30 degrees outside. I just put 20" rims on and I noticed just yesterday when I needed to make a pull to get in front of a truck... I had zero turbo action. I doubt seriously its the added weight of the wheels. It was not turbo lag it was simply no turbos at all. I have no gate rattle, no whining, not oil leaks that I can tell, no smoke from tail pipes that I can see, but I have smelt an odd burnt smell occasionally inside the cabin. Hard to tell if it smells like burnt oil. It sort of does and It sort of doesn't. Car runs great other than no fun power!
I was anticipating the turbo replacement but I'm not ready yet. I had other things I wanted to mod. This changes my plan! So I am now looking at replacing the turbos (With stock ones because from what I am reading unless I plan on exceeding 600hp there is zero need for upgraded turbos, I'm planning on a 400-450hp build only I'm 52 years old and drive back and forth to work interstate mostly and although I feel 20 years old in my head I plan on being calm driver but ist nice to know there is something there if I'm feeling it
Anyway, New Turbos, new upper downs (because the they are right there in front of your face if your replacing turbos so I don't want to hear it takes 12hours for UDP's at that point because now its 10 minutes), heat exchanger and cold air intake all at once to start my platform. Then I will do LDP's and CBE later Then a tune or Race chip
Here is my question for all. IF my turbos are indeed out...Can I drive the car safely for several months until I have the cash to do the repair. I have read I can, but in the same paragraph it said but be prepared for repercussions! So that was confusing. If its safe to drive how are there repercussions for doing so. In my mind If I drive the car like grandma for four months I should be fine but you tell me...am I rolling the dice on anything here?
