121 - 127 of 127 Posts
I recommend you buy a replacement overflow bolt. The overflow bolts are prone to issues.
- 5mm Hex (for overflow bolt) Part# 31361-1XJ0A
- 19mm Socket (for drain bolt)
Thanks, but I need to know the thread size or size of the hole.
The ATF filler adapter shown above indicates it's a M8*1.0, so I assume the overflow bolt would be 8mm with a 1mm thread pitch.
  • Helpful
Reactions: RedS
