21 - 40 of 44 Posts
Thanks for this add. 66K for a new water pump is a little early! I'm glad warranty covered the cost.
It was a very tiny leak. Like drip seepage. My buddy is the shop foreman so he just called it to replace it early for me. Did my belt replacement and pulley adjustment with AC recharge as well. Maybe water pump leaks arent as common in the warmer USA climates?
I havent driven my car since winter hit but I remember a slight whistle coming from the engine bay. Could be belt could be turbo.
I recently had the stealership perform a 7-qt drain and refill on my transmission @ 31k miles. Definitely made a difference in improved upshifts - seems quicker to me.
Is there any advantage/disadvantage doing a full flush and fill vs just a drain and fill?
Full flush (or a 3 X drain and fill) is required if you go full interval before changing out the fluid. I would consider a full interval to be 50k-60k miles on this car and the Nissan Fluid. Not sure what the official maintenance schedule has for it. May be a "good for the life of the car" interval, which will be a self fulfilling prophesy!
Anyway, those who want to keep it simple can do a single drain and refill every say 15-20k miles and that would keep the fluid fresh in the gearbox in perpetuity.
I'm at 23K miles and at my next oil change, I'm going to have the ATF drained and refilled.
Reactions: IridiumRS400
Cost. The stealership was going to charge me almost double for the full flush vs "just" a 7 qt drain & refill. With this transmission fluid to be supposed "lifetime fluid", if I have the drain & refill performed periodically, say every 30k miles, that should keep the transmission performing at its best for as long as I own my Q.
If you ever decide to sell your Q60, let me know.
Discussion starter · #30 ·
It will be interesting to see how the VR30 ages. Is it true that turbos generally don't last more than 150,000 miles?
I was curious to see how much a new turbo is from Infiniti:
(14411-5CA3D - Turbocharger. A complete turbocharger assembly - Genuine infiniti Part)
Part Number: 14411-5CA3D (low pressure / 300 HP version)
$1,656.22 each or $3,312 for both, and if you can't install them yourself, add around $1,000 for labor = $4,312.
I am starting to think this is like buying a fine German car. To minimize financial obligations, only buy it with a warranty, then move on to something else before the warranty expires.
In full transparency, I have never owned a turbo car, so I am only going by what I have read and comparing it to my long (and VERY reliable) SR20DE / KA24DE / VQ30DE / VQ37VHR history.
I really hate to say this, but I am starting to think the VR30 isn't for me, as it doesn't seem to have the long term reliability I am looking for... and by that I mean only oil/filter changes, spark plugs and coolant replacement for the fist 250,000 miles.
TL;DR
I really like the Q50 but I worry about the long term costs to keep it running.
TL;DR
Once you're out of warranty, there's zero reason to pay dealer prices for parts or service. It took me less than a minute with my pal Google to find those turbos for $600 less each, and I bet you can do even better than that if you spend 5 whole minutes.
Not that a $2,500-3,000 repair is fun, but this is all speculation at this point and those things might last 200k miles.
its not realistic to expect ANY turbo besides on a diesel to live 150,000+ miles. it can certainly happen, im saying dont bank on it. its just not realistic to expect a part that whirls around at anything from 100,000 to 220,000rpm to last for 2,500 engine hours (150,000 miles at 70mph, engine load not taken in to account). people have come to expect to replace timing chains at the the 150K - 200K mark on newer engines, turbos shouldnt be any different.
also, youll never actually pay $1K+ for a turbo, those are fake dealer prices. labor will be an issue but any major work will be expensive.
again, EVERY vehicle has its flaws. for some, its a particular part on the engine. others, its a transmission gremlin or interior issue. every single vehicle choice is a balance between time and money when it comes to extended ownership intervals.
if you want a reliable vehicle, pick something with 4 cylinders or an inline 6, non turbo, lower hp numbers, and a lower end trim. less crap to break, less power to stress the components, and a boring life.
Discussion starter · #33 ·
I see...
If the $1,600+ Infiniti turbos don't last, I'm sure some half price, offshore no-name brand will.
I have worked on cars for 40+ years... cheap parts are very expensive because they are not built to the same spec and don't last.
Discussion starter · #35 ·
You are funny!!!
I was looking for a replacement for my 6 speed manual G37 and since I love Infiniti I put the Q50 on my short list.
As I learned more about the car and engine, I am starting to see it doesn't meet my reliability/cost requirements.
On my G37, in the last 10 years, my maintenance costs consists of: tires, brakes, and oil changes.
I want to thank everyone for their input and thoughts on this topic.
I do appreciate it!
You’re welcome and good luck with your decision! We all wish you the best
Also, if you want to steer clear of turbos, but do want reliability and some fun; the new GR86/BRZ is getting great reviews, and both Toyota and Subaru are know for being mechanically rock solid. Plus, it’s available with a stick.
TL;DR
Get a Q50 with the 3.7L VQ37VHR then. That engine is pretty bulletproof, but had issues of it's own like the infamous oil galley gasket blowing out. I have no reason to believe the VR30 won't be anything but reliable. As long as you do your maintenance and use a high quality synthetic oil, you will be fine. As @SkylineDreamz said, let the engine warm up before getting on it and let the turbos spool down before turning it off. I bought my car new and plan to keep it for a very long time, so mine is on a regular diet of Amsoil signature series 0W-20.
And they only need a 150 nitrous shot to be relevant. Apparently the turbo FA24 was actually considered but the official reason for not using it was "center of gravity" issues. I believe it was more about keeping the car away from the performance level of the WRX. Who would buy a 3500lb sporty car with 271hp/258tq when they could buy a 2900lb sports car with 271hp/258tq. Instead, it gets a buzzy n/a pancake with 230hp/180tq.
You end up with a "sports car" that's slower than a V6 Camry, slower around a figure 8 than an outdated RWD (or AWD) Q50, and can't even brake faster than Hyundai Sonata.
Many reviews of this car list specs and then IMMEDIATELY say "it isn't about the numbers". Yeah, that's because it doesn't have an numbers worth mentioning. Minivans aren't about the numbers either.
21 - 40 of 44 Posts
