Jb4 logs (map2,5,6) advice needed
6.8K views 15 replies 5 participants last post by  DrJason
#1 · (Edited)
Did some data logging after installing fuel wires. Afr seem a bit low for having fuel wires just wanted to make sure everything looked good in these maps. Will be running map 2 and 6 most of the time. Let me know if anything stands out and also if I should adjust my map 6 boost ramp. Also this is for a stock q50 3.0t premium. Thanks! It's goes map 6,6,5,2. I also added my map 6 log with WOT only.
94940
94941
94942
94939
94943
94945
#2 ·
@Boxy or @Ddnspider may be able to help you out with your particular request, if you can dump the log files into a .CSV format
it certainly would make things a bit easier to review however.
Also love that profile picture. Hah
#6 ·
Hey my bad about that I tried to get them in graph from but they wouldn't upload ill try and figure it out for you all I appreciate that.
#4 ·
I prefer graphical displays of the data logs vs. spreadsheets also. It's easier to evaluate what's going on.
#7 ·
Fr the app you should be able to select the parameters you want graphed. You want both boost banks, both afr banks, ign1, trims, rpm as a minimum.
#8 ·
I'm not 100% good at reading JB4 logs but it seems like your AFR is at good place during WOT.
Are you using 91 or 93 Oct gas?
#11 ·
Ignore timing drops right at the shift. Otherwise shoot to keep it at 5 degrees or above, but look for timing to ramp up with rpm.
